Rank: Administration
Groups: Guests
+1
Nice job on the videos.
My washer makes noise and fills very slowly when using cold water.
washer fills up very slowly when using cold water and also making humming noise.
I replaced bad lid switch but panel on my kenmore model #110.26955690 reads lid not closed what do I try next please HELP
Using things signifies that they may eventually bust. When and if they bust, you should think about downgrading your appliances, rather than replacing them. This can save you a lot of money.
thanks for the share and i am good with getting the right way to mend my washer if it gets any wear anytime, if not then it is best
my washer is making a noise during spin cycle:confused:
