dstoliby
#1 Posted : Friday, January 13, 2012 11:03:39 AM(UTC)
dstoliby
How Do I Test The Windings On My Dryer Motor ? The Part # Is 8066206
ApplianceJunk
#2 Posted : Friday, January 13, 2012 11:27:54 AM(UTC)
ApplianceJunk
I would use a multimeter to check for continuity on the run and start windings.
Here is the tech sheet for your dryer. It shows the readings you should get on the windings.
File Attachment(s):
Wiring Sheet - 8578889.pdf (239kb) downloaded 7 time(s).
dstoliby
#3 Posted : Friday, January 13, 2012 3:14:42 PM(UTC)
dstoliby
Thanks For The Diagram, But Which Wires On The Motor Are The Start Winding And The Main Winding. There Is Two Individual Bare Copper Wires On One Side And There Is Two Bare Copper Wires That Are Joined Together On The Other Side. There Also Is A Blue Jumper Wire, So Please Tell Me What Wires Are The Winding Pairs?
