1810garym
#1 Posted : Friday, January 13, 2012 7:54:16 AM(UTC)
1810garym
Found fridge/freezer not working, lost contents. No cold, no compressor sounds. Everything else works, lights, fan water just NO cold!
#2 Posted : Friday, January 13, 2012 8:23:43 AM(UTC)
Most probably a bad motherboard in the back AP4436216. You can remove the cover and check the back for bad solder joints behind the big power relay.
