Caliche
#1 Posted : Monday, February 23, 2009 10:58:00 AM(UTC)
Caliche
Have been having trouble with the water dispenser. I haven't been able to get any water recently. A few ice cubes are produced every now and then, but the water has stopped completely. Do any of you have any suggestions/solutions as to what is the cause of this?
Also wanted to know if and how it is possible to remove the front water dispenser panel? I have seen the diagram, but have not been able to figure out how to do this. Does it require the removal of screws or any plastic clips?
beenthereagain
#2 Posted : Monday, February 23, 2009 1:28:20 PM(UTC)
beenthereagain
Groups: Expert
it sounds like the problem is in the water solenoid valve, back of fridge, you do not really want to remove the front panel, no reason to, it breaks easy . and besides your problem aint there.
