Start/resume light is blinking nonstop and will not run, Any ideas? I think I have reset by pushing heated dry and normal buttons until all lights are on. Pushed cancel drain and still nothing. Need all advise I can get. Thanks
Most likely the problem is a stuck key on the control panel. The control panel has to be replaced. If you need the right part number, post the rest of the model number and the color of the control panel.
