Gene, you mentioned in a previous post to freelance 101 that he possibly has a defective E.O.C. you stated the part number as being AP367441 but the part number listed on the detailed breakdown is AP4088560 which one is correct ? i have the same thing going on with my range as freelance does (same range and model) do you have any idea if replacing the EOC fixed his problem ? i also have concerns as to the accuracy of the oven temp, i have checked it with an oven thermometer and appears as it is 15 degrees off, how do i adjust this ?
