Pat Self
#1 Posted : Monday, February 18, 2008 10:02:20 AM(UTC)
Pat Self
I have an electric stove that appears to have mice in the insulation of the oven is there a way to replace the insulation so it won't smell when I turn the oven on?
#2 Posted : Monday, February 18, 2008 7:58:51 PM(UTC)
If you are talking about the temperature insulation between the inner and the outer oven bodies - it is not replaceable.
For more accurate advise I need the complete model number of the unit.
JGDolecki
#3 Posted : Wednesday, February 18, 2009 12:54:33 PM(UTC)
JGDolecki
I need to replace some of the insulation in the upper part of my Hotpoint electric stove Model # RB735G0J2AD due to the invasion of a small critter. Could you tell me what kind of insulation I can use?
#4 Posted : Wednesday, February 18, 2009 3:40:09 PM(UTC)
As far as I know such temperature insulation is not serviceable. If the damage is significantly low you can still use the range.
JGDolecki
#5 Posted : Monday, February 23, 2009 9:24:42 AM(UTC)
JGDolecki
Hot Point Model #R B735G0J2AD
Thank You JGDolecki
