swcrdc
#1 Posted : Sunday, February 22, 2009 12:36:13 PM(UTC)
swcrdc
dryer will only start and run in cool down mode. what could be wrong ?
#2 Posted : Monday, February 23, 2009 2:51:36 AM(UTC)
Your Model Number is missing 3 digits from the end.
The following are for a LER7620KQ1
Model LER7620KQ1
And the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203979703.pdf
Since the motor does run, you know that the voltage , motor , thermal fuse in motor circuit , push to start relay and door switch are all OK.
All that is really left is a bad connection or the timer.
swcrdc
#3 Posted : Monday, February 23, 2009 5:32:07 PM(UTC)
swcrdc
Thank You Denman I Found A Set Of Contacts Inside The Timer That Had Welded Together. Once Opened The Black And Blue Contacts Could Close And The Dryer Is Working Properly. I Will Still Replace The Timer As Those Points Are Fried. Swcrdc:)
