ken rapoza
#1 Posted : Monday, November 19, 2007 3:53:19 PM(UTC)
ken rapoza
Dishwasher leaking from the right front at the bottom of door and also leaking from where the float shaft comes out at the bottom of the dishwasher.I called a local appliance center and the tech told me to make sure the float shaft moved free because if it does'nt it could cause the dishwasher to over fill ,he also told me it could also be a bad float switch.I checked the float shaft made sure it moved free. Ran the dishwasher and it still leaked.I then replaced the float switch, ran the dishwasher again and it still leaked. Any help would be appreciated. Thank you.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
Kenmore Elite 665.13929K015 Dishwasher Leak (Dishwasher Repair)
by JROTN 12/22/2022 5:12:45 PM(UTC)
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 10/4/2022 5:16:08 PM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4/22/2021 1:13:56 PM(UTC)
dishwasher leak varies (Dishwasher Repair)
by scottsasa 1/3/2021 4:23:28 AM(UTC)
Delayed dishwasher leak (Dishwasher Repair)
by budflanksteak 12/11/2020 5:03:57 AM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 5/14/2019 1:50:41 AM(UTC)
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
