ebcravens
#1 Posted : Tuesday, January 10, 2012 2:27:09 PM(UTC)
ebcravens
Turn on, fills with water, wont agitate....
Move dial to spin, empties with water, won't spin...sometimes door stays locked after shutoff...
Motor not humming, no refuse below coupling...
When it wont spin, low buzzing from door lock/switch...
Took apart door lock assembly, cleaned all contacts, and wiring harnesses, still no progress...
Could I need a new door lock/switch?
Is there a way to bypass lock safety feature to see if washer then works, isolating the problem?
Thank you appliancepros
sidfink43
#2 Posted : Wednesday, January 11, 2012 5:52:37 PM(UTC)
sidfink43
You should have found some tech notes under the top or inside the lower service panel. Use them to test the main control unit and the door lock.
If you need more info please post the full model number. There should be a 110 or 417 in front of the 8 digit number.
ebcravens
#3 Posted : Thursday, January 12, 2012 10:06:20 AM(UTC)
ebcravens
the full model number is 417.43042200....
have not found tech notes.
thank you for any help appliance pros:)
sidfink43
#4 Posted : Thursday, January 12, 2012 4:50:04 PM(UTC)
sidfink43
Here is a link to a service manual. Yours is a Frigidaire made machine for Sears
