dlehnhardt
#1 Posted : Tuesday, January 10, 2012 7:36:51 AM(UTC)
dlehnhardt
White-Westinghouse LA800M washer
After my washer finishes filling it starts making a loud humming sound and won't agitate, drain, or spin.
I've tried every cycle on the knob with the same results.
I can turn the agitator by hand.
I drained the water by hand, then switched it to SPIN. It actually started to drain and also started making a lot of noise. The lid was closed so I couldn't tell if the agitator was moving. I noticed a little smoke coming from the lid switch so I shut everything off quickly.
My first thought was that the motor was locked up, but if it drained does that mean the motor still works?
sidfink43
#2 Posted : Tuesday, January 10, 2012 5:39:44 PM(UTC)
sidfink43
The problem is likely in the transmission, and given the age of the machine you are ready to replace it.
