azcowboy
#1 Posted : Monday, January 9, 2012 6:36:10 PM(UTC)
azcowboy
The pump is an askoll m65. The shaft to the impeller is broke looks like it corroded in to. It looks like plastic part that the shaft comes out of can be removed from the motor. Is it possible to only replace that one piece instead of the complete pump?
#2 Posted : Tuesday, January 10, 2012 5:53:06 AM(UTC)
The pump is only available as a complete unit.
Part number: AP4359998
Click on the picture for more views and info.
drain pump repair (Washer Repair)
by gibsonhelp 1/2/2009 11:10:59 AM(UTC)
