dagnabitamana
#1 Posted : 13 years ago
dagnabitamana
Hi all,
I have an amana dryer nde2335ayw. I am attempting to wire the control panel back together but the original diagram is missing. some help would greatly be appreciated as my family and i are getting tired of hanging out clothes to dry.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
UserPostedImage
dagnabitamana
#3 Posted : 13 years ago
dagnabitamana
i actually have that one printed out it doesnt match up at all. on the back of the timer i have the letters gy, yl, rd, or, m, wh, and s. the wires for the motor are colored as follows: pink, yellow/black, orange, pink and white green and yellow, grey, pink and white. some of the connectors shaped like this |-|and some like this -. its just not adding up to the diagram. the timer motor part number is AP4047639. so you can see part of what im looking at.
#4 Posted : 13 years ago
If you click on the picture in the parts and get the second page then in the Q&A there is a question on the wiring.
There is a link there that opens a wiring diagram for a different unit but it seems to match your unit in many ways.
I cannot say which diagram is correct.
You will have to trace each wire to see where it is connected.
You also mention the motor wires which seems strange when you say you are reconnecting the timer.
dagnabitamana
#5 Posted : 13 years ago
dagnabitamana
sorry about being unclear. i am tracing wires from the motor there are only three coming up from it to the timer a blue, yellow and black, and black a white which splits into three different wires inside the control panel. i dont understand how to get to the other diagram you were speaking about. is it actually in the parts section of the website.
#6 Posted : 13 years ago
Yes it is in the parts.
Often if you click on a part's picture a new page will open with more views , info and a Q&A section.
Click on the Q to see the A.
In this case it was the 4th question when i clicked on the timer.
Anyway here is the link. the A said it was for a MDET236AWY
http://www.appliancepartspros.c...=5174207&NewWindow=1
dagnabitamana
#7 Posted : 13 years ago
dagnabitamana
close but no cigar denman. i finished my wiring tracing and tried to start it and it started but the it burnt the door switch so im getting close but ill have to be careful
#8 Posted : 13 years ago
Sorry but I cannot be of much use here.
I currently do not have access to other info sources.
#9 Posted : 13 years ago
See the attachment for a tech sheet that should be for your unit.
Also the following manual supposedly covers your unit.
16026315 Maytag Amana Dryer Repair Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
File Attachment(s):
nde2335.pdf (300kb) downloaded 21 time(s).
