llotin01
#1 Posted : Sunday, February 22, 2009 6:43:43 AM(UTC)
llotin01
My Whirlpool Quiet Partner II dishwasher, DU1100XTPS7, will not drain. When i press the Cancel/Drain button I can hear a faint hum coming from the pump under the dishwasher. No clicks, no motor movement, nothing. Any suggestions on what to check? I already pulled the dishwasher out and pulled the hose to allow it to drain out.
#2 Posted : Monday, February 23, 2009 3:35:07 PM(UTC)
Model DU1100XTPS7
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208572216.pdf
Since you have pulled it out I assume you have checked for a plugged drain hose.
Could be your pump Item 17 in "Pump & motor parts" is either shot or has something jamming it. If it is the part that is humming you know it is getting power.
llotin01
#3 Posted : Tuesday, February 24, 2009 11:37:10 AM(UTC)
llotin01
Thanks for getting back to me. No blockage in the hose. I pulled the pump (part #17) and pressed the cancel/drain button. It does spin! Happy about that. Looking inside where the pump connects, I can pull up the rubber flap and still no blockage. Could there be something in the Sump (part #4) that is blocking it? If so, is it accessible from underneath the dishwasher or do I attack it from the inside under the spray arm. Thanks again.
#4 Posted : Tuesday, February 24, 2009 3:36:56 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
whirlpool dishwasher will not drain (Dishwasher Repair)
by joeruscito 8/9/2009 12:46:29 PM(UTC)
