A slow drip has developed from my water dispenser, it started about 3 day ago. It is about 1/2 a cup per day. The fridge is working fine otherwise. Does any one have any thought on this? Thanks, Dave
Ahhsooo, the usual suspect is the water inlet valve... A buildup of calcium or minerals in the seat of the valve will allow seepage and your symtom drip... Suggest a disassembly and cleaning or replacement to remedy your problem... APPros will have a replacement valve with further research my friend...
Groups ready for retrieval: Registered
any other suggestions, I replaced my valve and I still get a leak
