gwb523
#1 Posted : Friday, January 6, 2012 2:00:01 PM(UTC)
gwb523
The water dispenser barely dispenses water. When I install the by-pass plug everything flows good. I have purchased 2 filters and neither one works. I have inspected for any kinked lines and I made sure I had proper water flow to the filter. I have checked the dual water valve and everything checks out. Again, when I install the by-pass plug the dispenser works great but when I re-install the brand new filters it doesn't work. I have flowed a good 4 gals of water through it in case there was an air lock.
Any suggestions?
Jschenk
#2 Posted : Saturday, January 7, 2012 12:35:20 AM(UTC)
Jschenk
After 4 hour of troubleshooting and labor, I've just finished repairing my fridge water supply. Had the same problem. I fixed it replacing the Base - Water Filter Part Number: AP3687338 (it's Frigidaire brand). The base has 2 water hose valves that works under pressure. After comparing this base with the base of the fridge I have in my garage (same brand!), I discover broken tiny pins in the valves. So, I swapped the base and now works like new. Hope it helps you.
GE Refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Jinxpalm 3/4/2015 1:26:52 PM(UTC)
reservoir for in refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Altfineart 5/27/2012 9:14:26 PM(UTC)
by reneecraig 4/28/2010 5:12:48 PM(UTC)
Hot Point Refrigerator Water Dispenser not Working (Refrigerator & Freezer Repair)
by mattsimonmx 2/10/2010 10:42:00 AM(UTC)
GE Refrigerator Water Dispenser Not Working (Refrigerator & Freezer Repair)
by cdadek 11/3/2008 8:27:28 AM(UTC)
