redrwut
#1 Posted : Saturday, February 21, 2009 9:18:14 AM(UTC)
redrwut
i was checking to see if the ignightor was working and lighting the dryer. the ignightor turned on and did light but took about 15-20 seconds to do. I turned the dryer off and reatarted it. as i was waiting, i tapped the side of the burner tube and it caused the gas to open and light. would that indicate a bad flame sensor or could it be just a loose connection? i cleaned off the sensor glass also. what are the symtoms of a bad flame sensor?
thank you
Louie
#2 Posted : Saturday, February 21, 2009 9:40:17 AM(UTC)
If the igniter will not allways turn the gas valve on, you probably have a bad igniter. If you have an amprobe, current should be well over 3 amps.The current may be near the trip point and tapping opened it up. Just order it from this site AP4037378
redrwut
#3 Posted : Saturday, February 21, 2009 9:44:29 AM(UTC)
redrwut
the ignitor lights up brightly every time.
redrwut
#4 Posted : Saturday, February 21, 2009 9:49:41 AM(UTC)
redrwut
i may have explained incorrectly. i tapped the large tube that the flame sensor is attached to. not the burner tube.
#5 Posted : Saturday, February 21, 2009 2:21:44 PM(UTC)
Repost this as either a failed heat or an intermittant one. If the igniter fails to open the gas valve it usually is a bad igniter.
gas hot water heater flame sensor (General Talk)
by normpete 1/21/2022 9:10:29 AM(UTC)
Gas dryer flame sensor not tripping (Dryer Repair)
by Guest 6/1/2021 7:32:22 PM(UTC)
Igniter, flame sensor, soleniods, thermal sensor all OK - but no heat (Dryer Repair)
by silentrunningpc 9/1/2016 4:34:36 PM(UTC)
No power to flame sensor, gas valves, or ignitor (Dryer Repair)
by ms0674 8/9/2014 2:37:45 PM(UTC)
Dryer Flame Sensor (Dryer Repair)
by TomHam 9/3/2013 1:00:20 PM(UTC)
Replaced gas coil, ignitor, flame sensor.. (Dryer Repair)
by dspcr 8/16/2013 4:12:54 PM(UTC)
flame stays lit for a few (20) seconds then goes out. could it be the flame sensor? h (Dryer Repair)
by grubxx96 11/11/2011 1:01:45 PM(UTC)
Kenmore replaced coils,ignitor,and flame sensor still no heat. (Dryer Repair)
by cfreeman 12/30/2010 10:31:48 AM(UTC)
Thermal fuse and Flame sensor wiring (Dryer Repair)
by cwizzards 5/7/2010 10:22:30 AM(UTC)
by Dangilligan 9/9/2009 5:34:55 PM(UTC)
relpaced coils and flame sensor and no heat (Dryer Repair)
by mjl 7/3/2009 2:20:19 PM(UTC)
Wiring Flame Sensor (Dryer Repair)
by TomGJohnson 6/9/2009 2:29:13 PM(UTC)
New flame sensor failure? (Dryer Repair)
by spiderberg 4/1/2009 6:54:40 AM(UTC)
Which wire to which terminal on the flame sensor? (Dryer Repair)
by supertramp 1/13/2009 2:22:16 PM(UTC)
flame sensor (Dryer Repair)
by sarrah76 1/9/2009 9:37:57 AM(UTC)
