APP sent me the same switch and wiring diagram I had. Here are some more photos of the old switch from different angles to help with the diagnosis. Thanks for your help. Tim
Tim,
Are you sure there are no S1 and S2 terminals on the switch?
There are only blank slits where the S1 and S2 tabs are marked.
Tim,
Give me a few hours (maybe till tomorrow) to find out what is going on.
Tim,
Today is Friday and I forgot about it. So it can be till Monday.
Hi Tim, After a few more searches and phone conversation with the Frigidaire tech support I found that the manufacturer had redesigned the switch for the dual surface element for the cooktop with the model number FEC30S6HSA. The part number for this switch is 318078200 which is Appliance Parts Pros part number AP3775555. Unfortunately this switch is much more expensive, but if you will go to the Appliance Parts Pros live chat and ask for Adam, he will help you. Gene.
Does this switch have adequate instructions? It does not look anything like the current switch. I did not see any tabs to connect the wires to.
Tim
It comes with the installation instructions.
I got the new switch in, everything works good, except the hot surface light is on all the time. The top is cool and all the switches are all off.
Any ideas.
Tim
