Jimnstella
#1 Posted : Monday, November 19, 2007 9:12:28 AM(UTC)
Jimnstella
Bake element quit working, broiler element works fine. Replacement element doesn't work either. Tested old element, has continuity. Is there a fuse or switch that might be bad? Thanks for the help. I hope we won't have to buy a new stove before Thanksgiving. Thanks, Stella
#2 Posted : Tuesday, November 20, 2007 5:03:52 PM(UTC)
There are no fuses or switches in the range.
Most likely the problem with your oven is a bad control board.
- The part number for the control board AP3417651
Kenmore oven not working after power outage (Oven Repair (including Ranges and Cooktops))
by Blue Cow 7/5/2009 12:39:47 PM(UTC)
Kenmore oven not working (Oven Repair (including Ranges and Cooktops))
by Ian 12/25/2007 7:00:27 PM(UTC)
by Van 12/22/2007 10:30:42 AM(UTC)
