Katheryn
#1 Posted : Monday, January 2, 2012 8:55:52 AM(UTC)
Katheryn
I have a whirlpool washer that won't fill with water, but it agitates and spins. Any ideas on diagnosis? Water level switch? Timer? Inlet Valves?
sidfink43
#2 Posted : Tuesday, January 3, 2012 4:31:14 PM(UTC)
sidfink43
The water level switch operates such that the machine will not start to operate until the water level switch has told the timer that the correct amount of water is in the machine.
So I would start by replacing the water level switch and see if that fixes things.
Whirlpool washer won't fill (Washer Repair)
by Jmccal7 9/9/2014 7:24:00 PM(UTC)
Whirlpool washer won't fill with cold water (Washer Repair)
by tjwinters 3/17/2013 12:43:54 PM(UTC)
Whirlpool Washer Won't fill (Washer Repair)
by jamie_pancake@yahoo.com 9/22/2012 3:32:02 PM(UTC)
by Wilmalcolm 7/28/2012 4:42:25 AM(UTC)
whirlpool washer won't fill (Washer Repair)
by rambo2 3/5/2012 8:36:41 AM(UTC)
Whirlpool Washer Won't Fill (Washer Repair)
by bjm46 11/15/2008 1:25:50 PM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
