I've tried using the Light wash and the Normal Wash, both times the machine stays in the wash cycle (for an hour:eek:-at which point I turn it off, as it has drained the hot water heater):(. How Can I make it cycle out of wash? And, what is the USUAL time for this machine to run in its entire cycle?:confused:
THIS FORUM IS DEAD!!!!!!! |
Thank you for the manual and tech info. We're renting, so we had none of the documentation for the unit. will check both of these and see if we can remedy the issue. If not, I'll be back...:)
