I am fairly certain the ccu needs to be replaced however the part diagram list two ccu items one behind the controls on the top right and one next to it to the back of the machine also on the right. one is listed as the mirco computer (part 13 on the diagram) the other as the controls interface (part 8 on the diagram).
I am looking for some advice to see which one is linked to the F1 error code. Here is I what I have done so far, I unplugged to reset board it clicks and locks door when you plug it in then beeps three times when you press start. When you run diagnostic it gives F01 code.
Before I ordered any parts I would unplug each connection one at a time and plug it back in to make sure it's not just a bad connection.
