fundyz
#1 Posted : Monday, January 2, 2012 11:04:58 AM(UTC)
fundyz
When replacing the inside glass of this Amana Gas Oven door, what would be the easiest way to do this. Do I need to order anything other than the replacement glass? Thank you for your help. Dennis
ramblinche81
#2 Posted : Monday, January 2, 2012 7:03:08 PM(UTC)
ramblinche81
Look at the schematic from the parts web site and look at how the door is pieced together.
The only thing I have seen from others is the door seal might have to be replaced if damaged during dismantling.
