2 Pages<12
jmin
#11 Posted : Thursday, February 19, 2009 3:24:42 PM(UTC)
jmin
The water is fairly warm, not hot and the level of the water is above the pump and below the arm with water on the bottom of the diswasher, probably a 1/2" minimum
#12 Posted : Thursday, February 19, 2009 3:39:21 PM(UTC)
Looks like the problem is somewhere in the heating circuit. You have to check the heating element and the high limit thermostat for continuity.
jmin
#13 Posted : Thursday, February 19, 2009 7:17:29 PM(UTC)
jmin
do you have any drawings? I have no idea where to start but certainly know how to check the continuity with a meter, the good news are the dishes are real clean, so I am guessing the water should be hot? Out of curiousity why would that make the diswasher continue to run?
Thanks for all your help!
jmin
#14 Posted : Thursday, February 19, 2009 7:21:43 PM(UTC)
jmin
I was just looking at the inside again and it looks as though the heating element may be cracked at the very front, would that cause the machine to continuously run?
jmin
#15 Posted : Thursday, February 19, 2009 7:25:41 PM(UTC)
jmin
It is a bit more obvious after moving it(element) a bit, do you have the drawings on how to replace the element? It doesn't look very healthy at all upon close inspection
#16 Posted : Thursday, February 19, 2009 9:35:30 PM(UTC)
As you can see on the diagram the heater is secured with the two plastic nuts (#3) under the dishwasher. You have to unplug the wires first. The new heater comes with the two washers.
- The part number for the heater is AP4325066
P.S. The control board keeps the dishwasher running until it senses the correct water temperature.
jmin
#17 Posted : Friday, February 20, 2009 5:16:25 PM(UTC)
jmin
Thanks Gene, I would like to buy you a beer! I will get the parts this week and let you know.
jmin
#18 Posted : Thursday, February 26, 2009 3:18:17 PM(UTC)
jmin
I replaced the element today (only $34) everything is cycling and the diswasher is working perfect, thanks very much for you help!
#19 Posted : Thursday, February 26, 2009 5:19:18 PM(UTC)
You are welcome. I'm glad you were able to fix it.
kenmore dishwasher not cleaning (Dishwasher Repair)
by dave11223344 5/1/2008 5:57:58 PM(UTC)
2 Pages<12
