My daughter washed some clothes the other day and the washer has a burning odor to it when doing the wash. She could have overloaded the washer. It smells electrical or rubber burning. I turned the washer over and the belt on the bottom looks good. We did wash some half loads and still have the smell. Any ideas what this could be or what I could do to repair?
Tub bearings maybe staring to fail and making the motor work harder then it should have to.
Originally Posted by: ApplianceJunk  Tub bearings maybe staring to fail and making the motor work harder then it should have to. Machine is 10 years old. Should I just replace it or is it a easy repair job?
