mrsg32401
#1 Posted : Thursday, February 19, 2009 6:50:44 PM(UTC)
mrsg32401
A friend gave me their duet dryer. I cannot get it out of delicate cycle mode. I managed to get the error codes to display it gives me F25 & then it gave me F01 after I hit a bunch of buttons.
#2 Posted : Friday, February 20, 2009 1:56:19 AM(UTC)
A Model Number would help.
mrsg32401
#3 Posted : Friday, February 20, 2009 7:24:19 PM(UTC)
mrsg32401
Sorry, WED9400SU0
I got it to give me the codes last night but then tonight it won't do anything. When I push the power button, it just beeps. I can't get it to give me any diagnostic code.
#4 Posted : Saturday, February 21, 2009 6:01:56 AM(UTC)
Model WED9400SU0
Here is a tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10110638.pdf
Try unplugging the unit for half an hour or so and see if it will reset.
Run the diagnostics
If the dryer ran OK before you received it then perhaps you have a loose connection or a wire has come off.
This is a fairly complicated unit so unless you can find a cause it may be best to place a service call. I would try to make sure that any tech that comes out has experience with this particular machine.
Perhaps someone here has actual experience with this unit and can help you.
mrsg32401
#5 Posted : Saturday, February 28, 2009 9:18:22 PM(UTC)
mrsg32401
Thank you for your information. It really helped. Looks like it ended up being the console electronics. I have it being delivered on Tuesday. Hopefully I can change it out without a problem.
