2 Pages12>
Andre Filipe
#1 Posted : Thursday, February 19, 2009 5:54:10 PM(UTC)
Andre Filipe
Hello everyone:
After a couple of visits by different technicians, it followed frustration, money wasted, and…my machine not fixed. I’ve decided to just do it myself to save money since now I “know” what the issue seems to be.
I’ve just purchased a new motor from Appliances Parts Pro and since my expertise in washer machines are close to none, I was wondering if replacing the motor is a major project or just a matter of unplugging and plugging cables.
Any help will be strongly appreciated!
TechnicianBrian
#2 Posted : Friday, February 20, 2009 5:41:00 AM(UTC)
TechnicianBrian
Most motors are simple enough to change as the wires are generally all captured in a connector of some type. The model number you provided is not in a normal Kenmore format, so I cannot speak to your specific washer, but as long as you can get to it, the replacement shouldn't be to difficult. BTW, after several techs looking at the washer and not repairing it, how did you arrive at it needing a motor?
Andre Filipe
#3 Posted : Monday, February 23, 2009 6:17:15 PM(UTC)
Andre Filipe
Thanks for taking the time to reply.
Well, like I said, 2 out of 3 said it was the motor that's how I concluded. I installed it tonight and it seems to work fine. The timmer, which was also one of their call is working, but it's missing the plastic cap that makes it turn.
Now, for some reason the machine is not spilling the water out of the tank; maybe it was the issue from day one...
Any ideas????
BTW, I got the motor from its own model # because the machine model # wasn't coming out for me either....
TechnicianBrian
#4 Posted : Monday, February 23, 2009 6:52:44 PM(UTC)
TechnicianBrian
Water not draining can have several causes depending on the make and model. Because I don't have that information, I will be rather generic in thinking you might have a lid switch failure. If the switch isn't closed the machine will not begin a spin or drain cycle. If I had the make and model, I could be a bit more specific in my suggestions.
Andre Filipe
#5 Posted : Monday, February 23, 2009 7:52:28 PM(UTC)
Andre Filipe
Hello Brian,
Here you have it:
Kenmore (stackable) +/-10 years old (maybe older)
Serial # MG2211718
Model# 98573120 85731 (this is how it reads on the machine, with this space)
Type No.
143-00
Thanks once again and hope we'll be a step closer now...
TechnicianBrian
#6 Posted : Tuesday, February 24, 2009 5:49:18 AM(UTC)
TechnicianBrian
Hey Andre,
Looks like your model is 110.98573120 make by Whirlpool. You said the machine wasn't draining, so if you set it for a spin cycle, what does it do? If it just sits there, then I am back to the lid switch as that will prevent any operation during the spin cycle. Does it fill and agitate when a cycle is started? Let us know what you are finding.
Andre Filipe
#7 Posted : Sunday, March 8, 2009 8:40:26 PM(UTC)
Andre Filipe
Hey Brian, sorry it took me so long, but I was out of town.
Ok, when I turn it to spin nothing happens then when I switch to a normal washing cycle it fills itself with water NON-STOP!
What's my next move now?! Thanks!
TechnicianBrian
#8 Posted : Monday, March 9, 2009 5:45:57 AM(UTC)
TechnicianBrian
Sounds like two problems. First, if the motor does nothing, no sound nothing when set for spin, I still would say check your lid switch. If you start a cycle and the water just keeps running no matter the position of the water level switch, either the switch is bad, or the clear hose that runs from the pressure switch to the bottom of the tub became dislodged when you changed the motor. Verify the tube is connected and check the lid switch operation with a meter. Also, after re-reading your original post, if might be a good time to recap what the original failure was since your posting was asking how difficult it is to replace a motor after having service techs work on your washer. It seems each post is not leading to a solution, but rather a different failure and I am not sure what the original failure was.
Andre Filipe
#9 Posted : Monday, March 9, 2009 3:33:00 PM(UTC)
Andre Filipe
Wow! It's getting way out of my league now Brian...
I was about to ask you to come over but I just realized you're in Oregon...are these parts simple to replace, cheap?
I am getting discouraged and don't really have the money to get a new machine now.
I don't know what the original issue was because my mom used to live here and all she said is the machine stopped working...she's no longer in the country but I could try to find out if you think it would help.
Thanks!
TechnicianBrian
#10 Posted : Monday, March 9, 2009 5:10:07 PM(UTC)
TechnicianBrian
Knowing what is wrong would go a long way toward solving the problem. Otherwise, you may end up spending money on part due to advice based on inaccurate information. As a technician, I like to deal in facts so knowing what the concern is allows me to ask better questions which eventually leads me to the possible problem. Without being able to trouble shoot the machine myself, I must rely on your input and use your senses for what it is doing.
As for the parts I suggested checking, they are not difficult to replace and as for cost, I would rarely use the term cheap when describing appliance parts, but by comparison, they are less expensive than a new machine. But we need to know what started the problem and what the problem is, or throwing parts at it will only get more expensive.
Guest (8)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Fan motor replacement manitowoc (Refrigerator & Freezer Repair)
by Guest 5/27/2023 4:35:45 AM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
Samsung dv40j3000ew/a2 wont start after motor replacement (Dryer Repair)
by rev1id 3/24/2021 7:38:30 PM(UTC)
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Washer wont drain, after motor replacement (Washer Repair)
by rweltz 6/15/2018 4:41:50 AM(UTC)
Dryer Motor Replacement - wiring (Dryer Repair)
by houkden1 1/9/2018 5:12:44 PM(UTC)
PYG2300AWW Motor Replacement (Dryer Repair)
by headmotty 2/27/2017 10:02:59 PM(UTC)
GE dryer Motor replacement (Dryer Repair)
by etshome 7/23/2015 12:50:21 PM(UTC)
by Washington3 2/6/2015 7:42:48 AM(UTC)
Found extra part during pump/motor replacement (Dishwasher Repair)
by msg1524 11/1/2014 10:27:19 AM(UTC)
dispenser motor replacement (Refrigerator & Freezer Repair)
by pusser 8/31/2014 5:05:31 AM(UTC)
LG drain motor replacement (Washer Repair)
by Kim KS 6/13/2013 5:52:23 PM(UTC)
Kenmore Ultra Wash Motor Replacement - need Serivce manual (Dishwasher Repair)
by GlennFord 4/14/2013 1:03:22 PM(UTC)
Auger Motor Replacement (Refrigerator & Freezer Repair)
by millhouse 12/19/2012 4:20:29 AM(UTC)
2 Pages12>
