B_WILSON
#1 Posted : Thursday, February 19, 2009 12:27:39 PM(UTC)
B_WILSON
Hi, Hope someone can help me with this one. All functions of my washer are normal except this: When in agitate mode, the tub does not slow/brake. The agitator DOES stop. When the cycle first starts, the tub will stop, but once the clothes and water get going CW, the tub can't overcome the momentum and slow. Consequently, the water/clothes get going crazy fast in the CW direction and when running a "large" load, water begins to wash over the top. Like I stated before, all other functions are OK. I did find two pieces of broken black plastic with grooves in them on the floor of the washer, but there is another piece they attach to since they do not fit together. (if that makes any sense). Any help would be greatly appreciated.
Drags1998
#2 Posted : Thursday, February 19, 2009 3:11:47 PM(UTC)
Drags1998
I believe that the "ONE WAY" bearing on the bottom of the TRANSMISSION has failed, The only fix is to replace the Tranny!!!!!!!
