When i push start button,dryer just hums and does'nt run.i disassembled to check motor.if i assist motor by turing it will run but won't run under load.i think it needs new motor, but want to know if some other part might be causing this problem before going through the exspense of replacing motor.
Sounds like a bad motor to me.
