Hi My machine starts up, partially fills, then drains and the light flashes 7 times. I'm not sure how to reset it, I've looked under the kickpanel but there isn't anything there. The machine wasn't used for about 6 months, then worked fine for a couple of weeks, now this has happened. Please help if you can, I'm not majorly technically minded :confused:
The model number you posted is incorrect. Verify and repost it.
