Amysmom
#1 Posted : 17 years ago
Amysmom
My washing machine will fill with water for about 30 seconds, then shut off. I tried some troubleshooting but to no avail. When I jiggle the knob, the water comes out for a half a second, then shut off again. Please help!!!!
Rudy Hahn
#2 Posted : 17 years ago
Rudy Hahn
Moved Washer ,water is not filling,only pump is running whe switched to spinn.
abbie
#3 Posted : 17 years ago
abbie
it sounds like it could be the timer or mixing valve, if you jiggle the timer knob and the water comes in the washer i would say that,s where the trouble is located.
Kenmore Washer not filling up with water (Washer Repair)
by Jamielynn 12 years ago
Kenmore washer not filling up (Washer Repair)
by steveolang 15 years ago
