2 Pages12>
raquelbowman
#1 Posted : Wednesday, February 4, 2009 4:10:17 PM(UTC)
raquelbowman
My husband overloaded the dryer and now it won't run. When you press the on button, it makes about 2 revolutions and then stops. You can also smell the heating element when doing this. The drum gives resistance when turned manually. How do we diagnose the problem so we can replace the broken part?
kayakcrzy
#2 Posted : Thursday, February 5, 2009 1:42:29 AM(UTC)
kayakcrzy
The problem is the the husband on this one. Actually, it needs a motor. Tom ApplianceEducator.com
raquelbowman
#3 Posted : Thursday, February 5, 2009 3:39:30 PM(UTC)
raquelbowman
Are you 100% sure? Thanks for your help!!!
kayakcrzy
#4 Posted : Saturday, February 7, 2009 4:09:14 AM(UTC)
kayakcrzy
the only other thing to check is to see if something did not fall into the blower wheel. take the back off the dryer, and if you are behind it on the left hand side is where the filter goes in. there are four 5/16s screws holding it in place. take those off, and also pull the lint filter out, and remove the 2 phillip head screws, and then slide the cover to the right, and it will expose the blower wheel. check it out, and let me know. tom [url=]applianceeducator.com - parts[/url]
raquelbowman
#5 Posted : Wednesday, February 18, 2009 2:44:24 PM(UTC)
raquelbowman
Okay, we checked the blower wheel and everything seems to be fine. Nothing stuck. Thanks for your help. Do you think we should just buy a new motor or check something else?
kayakcrzy
#6 Posted : Wednesday, February 18, 2009 4:13:44 PM(UTC)
kayakcrzy
It has got top the motor then. Tom
raquelbowman
#7 Posted : Thursday, February 19, 2009 3:43:24 PM(UTC)
raquelbowman
what about the belt? Or, is that what we just checked? I would expect the belt to be rubber - correct?
kayakcrzy
#8 Posted : Friday, February 20, 2009 3:22:02 AM(UTC)
kayakcrzy
It still sounds like the motor to me. If the belt looks worn replace it too. Tom ApplianceEducator.com
raquelbowman
#9 Posted : Friday, February 20, 2009 4:28:10 PM(UTC)
raquelbowman
where is the rubber belt located so we can check it?
kayakcrzy
#10 Posted : Saturday, February 21, 2009 3:32:47 AM(UTC)
kayakcrzy
It is wraped around the drum. Look how it goes on, before you take it off. Rib side down. Tom ApplianceEducator.com
Guest (5)
2 Pages12>
