onatoli
#1 Posted : Tuesday, December 27, 2011 8:13:30 AM(UTC)
onatoli
How do you get the door lock switch to replace it on a Frigidaire Front Loader model FWT445GES1? I have removed the top and the rubber boot, but there just doesnt seem to be enough space to get to the connections. Do I have to remove the front panel? If so, how do I do that? I also received a modified switch, somewhat different then the original. Is the wiring the same as the original switch, it appears a little different?
sidfink43
#2 Posted : Tuesday, December 27, 2011 4:52:29 PM(UTC)
sidfink43
Here is a link to a service manual for that model. You may not have need to take off the gasket; when you go to put it back on be sure and have a helper.
http://www.emaservicetips.com/p..._TumbleActionWashers.pdf
