My dishwasher clean light is flashing, I reset it using the normal wash-heated dry sequence, but when I hit the cancel drain, it starts to drain, stops, then the clean light starts flashing again. I can reset it again, but I am afraid to try and use the dishwasher again in fear that it will just fill up and not drain. The water in the dishwasher (when a cycle started after the reset), was hot, so I don't know if the element in the dishwasher is bad or not.
