I'm not getting power on my KA dishwasher. I took it apart and I get power to the circuit board, but no lights come on, on the control panel. I'm thinking the circuit board is bad. Am I off base on this idea? Thanks for any help...
did you get this problem resloved? Same thing happening to mine.
-Brian
Yes I did. It was the fuse on the circuit board. it's a $14 part. be sure to follow the instruction to a T. I didn't and had to buy another fuse...
The fuse was white on mine and it was an easy fix
here is the part: Dishwasher fuse kit - Includes wire harness and instructions. When replacing this fuse, included wire harness must be replaced as well. Part Number: AP3178588 made by WHIRLPOOL ![UserPostedImage](http://www.appliancepartspros.com/img/dot_216.gif) Our Price: $14.07
Thanks. I removed the fuse and checked the ohms and also by-passed it and the washer worked. It's the culprit! I'll be ordering this new part tonight.
-Brian
[I have the same problem where do I look for fuse?quote=jstyers;63405]here is the part: Dishwasher fuse kit - Includes wire harness and instructions. When replacing this fuse, included wire harness must be replaced as well. Part Number: AP3178588 made by WHIRLPOOL ![UserPostedImage](http://www.appliancepartspros.com/img/dot_216.gif) Our Price: $14.07
We had this same problem. Followed the advice here and the dishwasher is working now! Thanks a lot!!
