suziguzzi
#1 Posted : Thursday, December 22, 2011 4:55:43 AM(UTC)
suziguzzi
I have to replace the motor of the dryer on my Frigidaire laundry center FLSE60RGS1. Can someone explain how I do this? No local technician available to do for me?:confused:
#2 Posted : Friday, December 23, 2011 2:15:55 AM(UTC)
Replacement parts for FRIGIDAIRE FLSE60RGS1 Lc - Frig/lowes | AppliancePartsPros.com
Here is a service manual if not exact it should be close to your unit.
Frigidaire 27 inch Laundry Centers Gas and Electric (5995381885) Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Since you have to open it up I would give it an overhaul.
Check the belt, idler wheel, front drum glide, felt seal, rear support bearing etc.
Give the interior a good cleaning and also check/clean your vent system.
Use a high temperature grease to re-lube the rear drum bearing/support.
Also be careful when you release the small ball bearing in the rear drum support. It likes to jump out and then play hide and seek which can waste a lot of time.
