TAKAUFF
#1 Posted : Wednesday, December 21, 2011 2:51:26 PM(UTC)
TAKAUFF
I have a front loading Whirlpool Duet washer and one of the pieces on the door hinge broke. It is the piece that connects the door to the washer and keeps the door in place when swinging shut. It is a little grey plastic piece about 2-inches long. Can I buy and install this peice separately or do I need a new door? New Hinge?
sidfink43
#2 Posted : Thursday, December 22, 2011 5:02:51 PM(UTC)
sidfink43
Your model number does not come up as a Duet Washer, and it doesn't look right. If you get the correct model number you can use it on this site to get exploded views of your machine and then you can see if the part is available separate. I imagine it is.
