SteveC
#1 Posted : 17 years ago
SteveC
My Kenmore Elite refrigerator won't dispense water but the icemaker is working. I assume that means that either the switch in the door is bad or that the water inlet valve is bad. I assume from reading other posts that the quickest way to find which is bad is to see if voltage is getting to the valve. Correct?
How do I get to the valve? Is it exposed or do I need to remove a cover or other parts to get to it? Looking at the back, where will it be? How do I recognize it? Will there be a connector I can disconnect to check for voltage? What am I looking for: Ac or DC? What voltage?
Can you tell me the correct part numbers for the valve and the switch? The model number, 50502990 doesn't look like a typical Sears part number.
thanks,
SteveC
christopherjamesodonnell@
#2 Posted : 17 years ago
my kenmore would stop dispending if I set the fridge below 42 degrees freeze up in th filter housing. this late caused a flood.
CHARLEY
#3 Posted : 17 years ago
CHARLEY
My dishwasher sears kenmore model # 363.16121100 won't drain water
Duet won't dispense water?? (Washer Repair)
by norwester 10 years ago
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 12 years ago
