bselff
#1 Posted : Tuesday, December 20, 2011 12:58:18 PM(UTC)
bselff
Good Evening,
I am trying to help my neighbor repair his old dryer which isn't heating. I have checked the heating coil & have continuity, I have checked the front (??) over_temp and have continuity but the rear (??) thermal whatever it is, has not continuity. The (2) units appear to be wired from the (??) bad thermal to the front (good) thermal, then to the heating element. Is the rear thermal (??) normally closed or is it normally open which is why I have no continuity. Any and all help is greatly appreciated, your help was great when I had to repair his washer. They don't have a lot of money and have 3 kids, so I don't mind helping them.
Thank You,
Bob
#2 Posted : Wednesday, December 21, 2011 3:29:33 AM(UTC)
Here are the parts
Replacement parts for KENMORE 11063932102 | AppliancePartsPros.com
If you go to the sears parts site they have the parts breakdowns.
All thermostats should be 0 ohms at room temperature.
On the heater you have a hi-limit thermostat and a thermal cutoff (fuse).
I think it is the cutoff that is blown.
On the blower housing you have a thermistor, it's resistance tells the control board what the temperature is so the board can control the temperature bu opening/closing the heater relay contacts.
Also there is a thermal fuse, this one kills power to the motor.
This is a fairly complicated unit but I would start by doing the following.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check the thermistor resistance.
Check that the heating relay contacts are open when not energized.
Check/clean your vent system.
Check/clean the blower wheel.
File Attachment(s):
63932102.pdf (321kb) downloaded 9 time(s).
bselff
#3 Posted : Wednesday, December 28, 2011 8:22:38 AM(UTC)
bselff
Denman,
The holidays or over and I have been back to my neighbors house to try and fix their dryer. I have finished all the testing of the components per your information provided. I have only found one issue prtaining to the termal cut-off . In testing it with an ohm meter, I get nothing through it, but again, I have no idea if it is normal open or closed, the tech document doesn't say what the ohm reading should be. All other components check fine per the doc and your information. Is it possible to jump those to wire for testing purposes only to insure that corrects the issue. I have attached a PDF file showing the results, I hope it helps.
Bob
Thank you again for all your effort and support
File Attachment(s):
11063932102 Results.pdf (34kb) downloaded 4 time(s).
#4 Posted : Saturday, December 31, 2011 3:17:27 AM(UTC)
Sorry for not responding sooner but I have been at the lake for a few days.
The thermal cut-off should be 0 ohms.
Here is my standard blurb if it is blown.
Check it with a meter, should be around 10 to 12 ohms.
Check the heater relay contacts. I think the motor and heater relays are the same but double check this as I am not 100% sure. If they are swap them to see what happens.
bselff
#5 Posted : Saturday, December 31, 2011 10:31:44 AM(UTC)
bselff
I have given him the parts to order and we will see what happens.
By the way, it must be nice to be on the lake, we have a boat which hasn't seen the water since we moved from Ca to (bfe) Az, it sits in the garage since it takes more time to tend to 20 acres than I thought and the closest skiing lake is more than 6 hours away. Thanks for all the help and I will post when it is repaired.
Thank You again,
Bob
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
electric dryer not heating (Dryer Repair)
by notimetowait 10/1/2010 6:26:06 PM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by 18wheeler 1/30/2010 9:16:47 AM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not heating (Dryer Repair)
by Danske 11/23/2009 4:19:41 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
electric Dryer not heating (Dryer Repair)
by RJ Trucks 7/28/2009 10:52:36 AM(UTC)
by Global Kiss 7/16/2009 10:33:02 AM(UTC)
