Dryer stopped in midcycle. Won't restart. I can hear the timer is one when I turn the knob. Push in and nothing. I have checked the power, pulled it out and cleaned the lint thing. I opened and closed the door, light does not come on (can't remember if its suppose to though), I pushed in the door switch, it clicks on and off. What could it be? Its a maytag model number PYE2300AYW
It could be the thermo fuse inside the dryer went bad.
I cleaned out all the lint. Took a switch off that was behind the control panel, and the thermal switch and the door switch. All checked out okay. Still won't start. Is there a start switch? Where is it?
