Traye
#1 Posted : Saturday, December 17, 2011 8:18:16 AM(UTC)
Traye
I need to replace the bottom glass on my double oven. It cracked. I found the part (AP4097034 Item 7) but I can only assume the handle holds the top of the glass to the door but what holds the bottom of the glass to the door? Is there some type of double sided adhesive? If so what is the part number?
#2 Posted : Sunday, December 18, 2011 4:50:59 AM(UTC)
The following should help, see page 30.
Download 16022506.pdf
No tape is required.
ApplianceJunk
#3 Posted : Sunday, December 18, 2011 5:49:01 AM(UTC)
ApplianceJunk
Frameless Door Disassembly
1. Remove oven door, see "Oven Door Removal"
procedure.
2. Place door on a protected surface.
3. Remove screws securing bottom trim to oven door.
4. Slide outer oven door glass and trim towards the
bottom of the oven door and remove.
5. Detach right and left trim pieces for outer door glass.
NOTE: Proceed with the following steps for door hinge,
door handle, and inner door disassembly.
6. Remove screws securing door hinge to oven door
chassis.
NOTE: Proceed with the following steps for door handle
7. Remove screws securing top door handle trim to oven
door chassis.
8. Remove screws securing door handle brackets to
inner door panel.
9. Lift upward on the lower side of the door handle to
release side alignment screws and rotate towards the
top of the oven door to release and remove.
10. Remove screws securing door handle to door handle
brackets.
NOTE: Proceed with the following steps for inner door
disassembly.
11. Remove screws securing lower door glass retainer to
door baffle and remove.
12. Slide inner door glass downward to release from upper
door glass retainers and remove.
13. Remove screws securing door baffle to door lining and
remove.
14.Remove insulation from oven door.
15. Lift inner glass and glass frame from oven door.
16. Reverse procedure to reassemble oven door.
