Ydnar
#1 Posted : Friday, December 16, 2011 2:07:59 PM(UTC)
Ydnar
Refrigerator worked when first started and set to 38F, but got too cold (30F). Increased temperature setting to 40F. Now no cooling. Evaporator fan works and there is no ice on evaporator coils. Freezer still working fine. Any trouble shooting ideas will be appreciated.
Jeff / APP Team
#2 Posted : Friday, December 16, 2011 8:45:42 PM(UTC)
Jeff / APP Team
Hello Ydnar. You will need to check the thermistor in the unit. It should read around 10,000 ohms at room temperature. If it is bad, the temperature reading inside the unit would not read correctly. You can test this with a multi-meter. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros...continuity-ohmmeter.html
Part number: AP3873826
Ydnar
#3 Posted: : Saturday, December 17, 2011 4:08:31 AM(UTC)
Ydnar
Thanks Jeff. Turns out the freezer was thawing out also, just took longer. I unplugged the unit for 15 minutes and now seems to be working again. Fridge is 38 and freezer at +3 so far. Hope it lasts so I can put the food back in.
