Dryer doesn't start, only chimes go ding ding ding, etc.
Originally Posted by: jgold Dryer doesn't start, only chimes go ding ding ding, etc. J, Check and make sure you can hear the door switch "click" when you press and release the door switch plunger on the door opening. Then enter the "service mode" Enter Service Mode: Dryer must be on before Service Mode can be entered. Press
Chime and Temperature Keys for 3 seconds, or until 3 beeps are heard. The machine will now be in Service Mode. Upon entry into Service Mode, the Sensor Bar Touch Data is to be displayed.
Diagnostic Tests The following table lists the various tests available while in the Service Mode. Before advancing to the temperature in next test, the current test running must be terminated. Press the following keys to access: Wrinkle Prevent
Displays “d” Display list of diagnostic codes.
Then rotate the
Cycle Selector Knob( slowly (one detent / click at a time) To sequence thru the diagnostic and help codes. Write them down, and let us know what the codes are if any. Thanks and good Luck, :) :) :)
