herb191
#1 Posted : Friday, December 16, 2011 9:35:18 AM(UTC)
herb191
We recently moved to a new house and when I went to use the dryer for the first time it would not start. The interior light comes on and I can hear the timer buzzing when the door is open (it stops buzzing when I close the door). The interior light seems dim to me but my girlfriend thinks its about the same as in the old house. I confirmed I am getting 220 coming from the plug in. I replaced the thermal fuse and nothing changed. Also, I don't think that it is the door switch because when I press it in the light on the dryer goes off (I could be wrong though).
So I am a bit stuck on what to try next. I am guessing it is ether the start switch or the timer? If so what is the best way of testing them without buying a bunch of new parts I don't need? Any help would be appreciated. Thanks.
ApplianceJunk
#2 Posted : Friday, December 16, 2011 9:37:59 AM(UTC)
ApplianceJunk
This is the thermal fuse you already replaced?
WHIRLPOOL Fuse, Thermal, part number: AP4043259
herb191
#3 Posted : Friday, December 16, 2011 9:44:30 AM(UTC)
herb191
It looks like it. This is the exact part I got and the site that I got it from.
http://www.********************...mal-Fuse/33001762/516650
Edit
It does not look like I can post URL's here. The part number I got from the other website was 33001762 and the it was item 516650. The website was repair ************....as a side note I would not order from them again it took forever for the part to show up.
herb191
#4 Posted : Monday, December 19, 2011 7:15:21 AM(UTC)
herb191
Any ideas anyone?
ApplianceJunk
#5 Posted : Monday, December 19, 2011 7:58:19 AM(UTC)
ApplianceJunk
Check for loose or burnt connection were the power cord connects to the back of the dryer.
herb191
#6 Posted : Monday, December 19, 2011 8:15:23 AM(UTC)
herb191
Everything looks new. I can see nothing that looks burnt and all the connects are tight. :(
