Bbaibee
#1 Posted : Friday, December 16, 2011 8:39:03 AM(UTC)
Bbaibee
Hello,
The baffles and screws are all missing from the drum. I have ordered the necessary parts, but how do I replace them? Do I take the top of the dryer off or something else? If so, how do I go about doing this?
Thank you!
Joe / APP Team
#2 Posted : Friday, December 16, 2011 8:53:00 AM(UTC)
Joe / APP Team
Originally Posted by: Bbaibee Go to Quoted Post
Hello,
Thank you!
Bbaibee,
You're right on target.
Unplug the power cord or remove power to the dryer.
Remove the lint filter assembly, then remove the two phillips head screws that hold the filter housing to the top of the dryer.
With a flat blade tool(putty knife), press in on the spring clips located in the seam between the top and front panel, approximately 3 inches in from each corner, and lift up on the corner of the top.
Raise and prop the top against the wall, or prop it up with a rod.
Open the dryer door, so you can rotate the drum so the mounting holes for the baffle screws can be inserted and the baffle can be mounted to the drum.
Good Luck and Thanks,
Bbaibee
#3 Posted : Friday, December 16, 2011 9:08:00 AM(UTC)
Bbaibee
Thank you so much! As soon as I get all of the parts I will give this a try.
You guys are awesome!!
Joe / APP Team
#4 Posted : Friday, December 16, 2011 10:40:47 AM(UTC)
Joe / APP Team
Thank You.
We appreciate it. Let us know how things went, when you're done.
