brittjohns
#1 Posted : Saturday, February 14, 2009 11:57:08 AM(UTC)
brittjohns
Our freezer stopped working a few days ago; it stays cool but doesn't keep things frozen. Then the refrigerator started warming up and is just barely cool. We had a refrigerator repair person affiliated with Sears come over and he said the compressor is bad and needs to be replaced at a cost of about $500. He suggested we might as well buy a new refrigerator and that it is normal for a refrigerator to last only 7 years or less. I find it hard to believe that it is normal to expect only 7 years out of a major applicance. Do you have any suggestions on what our next step should be? Thanks.
kayakcrzy
#2 Posted : Saturday, February 14, 2009 12:51:48 PM(UTC)
kayakcrzy
sears don't know jack!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
take the overload and relay off of the compressor, and replace it. i bet it works. i do it everyday. or, if you want, buy a hard start kit, and put it on. the part # on that is rco410. if it works, call sears back up and ask for your money back. those crooks!!!!! let me know how it goes. tom applianceeducator.com/parts.htm
#3 Posted : Saturday, February 14, 2009 3:17:40 PM(UTC)
If the unit seems to be cycling normally.
You may want to pull the covers from the evaporator coil and check them.
If they are heavily iced over, you have a defrost problem.
Also make sure the fan in the freezer is running.
If it is, reply back with a Model Number and I am sure someone here can walk you through the repair.
