cadmn
#1 Posted : Friday, November 16, 2007 3:10:26 PM(UTC)
cadmn
the drum on the ice auger is broken I have a new drum but I can't get the crushers off the main rod to replace the drum everything is apart except for the choppers & I can't get them off.
#2 Posted : Friday, November 16, 2007 3:35:32 PM(UTC)
If you already removed the crusher housing (#37 on the break down diagram) from the ice bin (#14 on the break down diagram), remove the retainer ring (#39 on the break down diagram) and you'll get access to the blades. Be careful - it could become a puzzle.
- Here are the break down diagrams for the Whirlpool refrigerator Model TS25AFXKQ03
cadmn
#3 Posted : Friday, November 16, 2007 4:28:50 PM(UTC)
cadmn
Gene I have removed all the above including #39 but I am unable to get any Of the blades/spacers etc. off of #27 so I can replace #28I've tried everything short of a pully puller. I was told they should just slip right off. But not with My luck thanks for helping.
#4 Posted : Friday, November 16, 2007 5:02:38 PM(UTC)
Are they rusted?
Try to use WD-40.
cadmn
#5 Posted : Friday, November 16, 2007 8:15:41 PM(UTC)
cadmn
seems part 31 is a nylon left handed nut/bushing take it loose & viola it all comes apart auger fixed. ya hoo
