Our Fridge is freezing. We replaced timer but that’s not it. We’re looking for some professional help. Freezer works fine but fridge is freezing food. What could be wrong? Haw can we test what’s wrong. Thank you for your help! Our model is tcx18padbbb
In which positions are both knobs for the temperature control?
they are set to the lowest right now. however we've been trying medium and nothing seems to work.
Try to set the left knob on "A" while the right knob set on "4". Wait about 24 hours to see the result. It's better to control the real temperature by using a mercury refrigerator thermometers. You can order one from APP. - The refrigerator thermometer Part number: AP3549145
will do, but I doubt it will work. we tried different options with that. If this does not solve the problem could it be the thermostat (the one you replace deep inside the fridge towards the bottom?) Also we noticed that the fridge sometimes goes on and after a second goes off. Seems like once it's on it's runs for long time.
Try to adjust the settings first and measure the temperature in both compartments. Post the results.
I did that and the fridge started to freeze even more
The exact measured temperature in both compartments might help.
