tpettit
#1 Posted : Tuesday, December 13, 2011 7:00:07 PM(UTC)
tpettit
front loader won't spin. wouldn't drain either but fixed that as i found a fruit snack plastic wrapper in the clean out drain thing that is behind the front panel. pump seems to be sucking water out but no spin. belt is fine. don't hear motor?
tried unplugging for 5 min. to reset but still no spin. Thinking it could be the door lock? any thoughts? can i take that door lock assembly out and test for continuity to see if it's bad? the l door locks just fine?
ApplianceJunk
#2 Posted : Wednesday, December 14, 2011 8:35:39 AM(UTC)
ApplianceJunk
Here is the tech sheet for your washer. Try the diagnostic test.
File Attachment(s):
Tech Sheet - 8182208.pdf (163kb) downloaded 38 time(s).
Guest (4)
