Tampa2
#1 Posted : Tuesday, December 13, 2011 3:45:43 AM(UTC)
Tampa2
I have a Samsung dryer that recently blew the thermal switch. After replaceing the switch and getting the unit up and working, it seams to want to run on with out shutting down. I have ran a test on the timed dry and on the sensor dry and it will count down like normal and get to 1 min and contiune running until I shut it down. I thought at first it may have been on the wrinkle relaease, but no such luck. Any ideas on where I should go next? Thanks for the help..
richard_hoang
#2 Posted : Wednesday, December 14, 2016 3:23:33 AM(UTC)
richard_hoang
Please let me know how to fix this problem. Have the same symptom, keep running after get down to 1 minute. It keep said cooling but not stop by itself until got overheat.
